Arc into segments
Command
Path
Arc into Segments
Modify > Drafting Aids
The Arc into Segments command converts a selected arc or circle into an equal number of segments, or divides the arc or circle into segments of a given length. The segments can be drawn as lines or polygons; the original object remains unchanged.
To convert a circle or arc into segments:
Select the arc or circle to be converted.
Select the command.
The Arc Into Segments dialog box opens.
Parameter
Description
Method
Number of Segments
Draws the specified number of equal segments along the arc
Segment Length
Draws segments of the specified length along the arc
Options
Draw Polygon
Draws the segments as polygons
Draw Lines
Draws the segments as lines
Creating arcs
